Who uses a PS3/360 Controller for which PC games?
1 Nov 2011
Portsmouth
As title, I'm interested in getting my PS3 controller set up, purely so I can play an emulator (Shadowrun from 1993!)
I've found the following, Motioninjoy list which states controller compatibility for several games, but would like your feedback and/or tips :p
I've used my Dual Shock 3 with Motioninjoy to play quite a few different PC games (Witcher 2, Skyrim, X3:TC) and various emulators too (PS1, PS2, SNES, GBA).
Could you find out for me how your friend got BF3 running on Xbox controller, I can't get mine to work? Also above someone says bad company 2, agai. I've tried xpaddder and that still doesn't seem to work. What am i missing here?
BF3 for heli + Jets, far easier than key + mouse.
Pad for emulated games.
I use an old logitech pad, about 7 years old and is still around £25 these days, it wasn't that much when i bought it :D
Maybe using PC version of xbox pad?
He was crying about plug and play on his controller, I think you have to have one type off controller and you go to microsoft site and download the actual driver for the controller for PC use.
I used to have it on one off the older controllers so I'm pretty sure it's a normal controller that it works with, one with or without the battery pack and you might need the lil extension. As I said I used to do this (ages ago) just google around and you'll find it :)
I just plugged it in and then assigned the buttons in the game options. It is a PC version of the pad, but works perfectly fine on an XBox 360.
All FPS on the traditional and best, keyboard and mouse. Use the 360 pad for Hitman Absolution, Batman, Saints Row 3 and those sorts of games.
I use a 360 controller for driving games, fighting games and games like Saints Row 3 etc.
About the only games i don't use a controller for are FPS games.
