- 10 Aug 2011
Will the FX 8350 bottleneck any of the more powerful GPU's? If so, which ones?
I don't think so. Not even the 7990 I doubt. Badly optimised games will be the culprit before that is.
It WILL bottleneck even 6850/5850 if it was CPU demanding games. Overclocking the CPU would help "reduce" the amount of bottleneck though.
So it's really down to what you play.
Like I said it's down to the game you play.I find that very hard to believe.
Any links to tests done to show that?
I am quite sure a 6850/5850 will be a bottleneck in any new game long before a cpu like the 8350 wil be.
Interesting. how about the 3770k? will that bottleneck any GPU?
Games like Plane Side 2, World of Warcraft.... yes it will.
I know that from personal experience as i play Planet Side 2 and my FPS can drop to 50 FPS along with a drop in GPU usage.
(Phenom II x6 1090T @ 4.1Ghz)
Always around bases if there are a lot of people around, which more often than not is the case, you can see as many as 50 players around a base attacking it which will put the CPU under a lot of strain.
BF3 Multiplayer; not a problem even on full 64 Player maps it holds firm, the FX-8350 will be even better for that.
so it does depend on what games you play and whether or not your bothered about holding constant 60 FPS in games like Planet Side 2.
It's nothing to do with directx...it more about the games need to be optimised better to use all CPU cores available.Planetside 2 is the only game I have where I drop frames regardless of settings with my PII x4. They really need to update the render engine to use direct x 11.
