Asus rog matrix platinum settings
Im just waiting for some extentions to move the molex connectors to a better spot
I am definely staying blue though.
That aint a Matrix Platinum weehamish. GET OUT! :p
Nice rig btw Kaapstad.
Should post a picture of my white toasty mess. Need to get some pictures since completing it.
Kaapstad. Noticed your settings above have the GPU Clock and GPU Voltage linked. Surely you could lower the voltage by un-linking them?
For 1300MHz i un-link and run 1325mv
I will give it a go when I overclock next time. At the moment I am still getting used to using the cards. I have noticed with my HD 5970s if I keep the volts down I get a better o/c.
Also having nvidia cards I am not used to being able to change voltages lol.
Ah i see.
Well basically with GPU Tweak locking the voltages, this gives an overly safe result. With the 7970 this seems to be well over the top compared to the GTX580 Matrix Platinum locked settings. Maybe because the 7970 chips have varied so much.
You will find you'll be able to drop the voltage quite a bit and still find it stable. Give it a go :)
Ah i see.
Have a look here in this thread or the Heaven thread in about 10 mins
I have just tried lowering the volts
Nice score coming up.:D
Thanks Rossi this ones for you
Nice!
Though c'mon you can get 1300Mhz ;) lower the memory a little if you need to, the GPU gives better results than the memory. 1800/7200 is a sweet spot for the memory
Nice!
I will give it a go when im off work at the moment I have got to go to bed.:)
Lol i never said it was? Well it basically is actually just a different shroud :P they basically the same card.
I just posted to show inside my case to Kaap thats all.
I know, i'm pulling your leg :p
Though, no they aren't. Different power management and PCB ;)
