Hi Guys
We have in stock and shipping now, the new revision series 4 Antec LSC cooling solutions.
Antec Kúhler Series 4 offer a higher pressure pump and split flow copper fin radiator design.
These two innovations drop temperatures further than previous versions without changing the price!
Antec Kúhler H2O 620 Series 4 CPU Watercooler (Socket Intel LGA 775 / 1155 / 1156 / 1366 / AMD AM2 / AM3 / AM2+ / AM3+) @ £47.99 inc VAT
Finally, there is a liquid cooler for the rest of us. The Antec KÜHLER H2O 620 delivers high-performance liquid cooling for your CPU in a quick, easy-to-install package. Unlike traditional liquid cooling systems, this self-contained unit comes prefilled and requires no maintenance. The voltage-controlled 120 mm fan, 3rd generation copper coldplate and airflow-enhancing low-profile pump ensure efficient cooling, while the estimated 50,000 hour pump lifetime means this cooler is even likely to outlast the system it cools. Easy-bend flexible tubing allows the KÜHLER H2O 620 to be installed in nearly any orientation regardless of the internal configuration of the case. Finally, the KÜHLER H2O 620 comes with peace of mind in the form of an industry-leading Antec Quality 3 year limited warranty on parts and labour. Take your PC’s Quiet Computing™ to the next level with liquid cooling performance at a price that rivals aftermarket air coolers.
- CPU Socket Compatibility: Intel LGA 775, 1155, 1156, 1366, AMD AM2, AM3, AM2+, AM3+
- Low profile pump ensures exceptional liquid circulation while preserving internal airflow
- Easy-bend tubes for maximum flexibility in radiator positioning
- Intelligent noise / speed control fan for quiet, efficient cooling
- Latest generation copper cold plate for optimal conduction
- Cooling Liquid - Safe, environmentally-friendly, anti-corrosive
- Fan Speed: 1450 - 2000 RPM
- Tubing Length: 330 mm / 13.0"
- Radiator Dimensions: 151mm x 120mm x 27mm
- Fan Dimensions: 120 mm x 25 mm / 4.7" x 1.0"
- AQ3 - Antec Quality 3-year parts and labour warranty
Only £47.99 inc VAT.
ORDER NOW
Antec Kúhler H2O 920 Series 4 High Performance Liquid CPU Cooler (LGA775 / LGA1155 / LGA1156 / LGA1366 / AM2 / AM2+ / AM2+ / AM3+) @ £82.58 inc VAT
Unlike traditional liquid cooling systems, this self-contained unit comes prefilled and requires no maintenance. The dual 120 mm Pulse Width Modulation (PWM) fans and 3rd generation copper coldplate ensure quiet, efficient cooling, while the 49 mm radiator is equipped to handle the highest performing CPUs on the market. Lastly, the included software helps you monitor and control the
Kühler H2O 920’s performance and allows you to customize its stylish RGB LED. Designed to unlock the maximum potential of your CPU, the Antec KÜHLER H2O 920 delivers exceptional cooling when you need it the most.
- Customizable RGB LED for brilliant illumination
- CPU Socket: LGA775/LGA1155/LGA1156/LGA1366/AM2/AM2+/AM2+/AM3+
- Fan Speed: 700 - 2400 RPM (PWM controlled)
- Radiator Dmensions: 151 x 120 x 49mm
- Fan Dimensions: 120 x 120 x 25mm
- Air Flow: 110 CFM
- 3 Year Warranty
Only £82.58 inc VAT.
ORDER NOW
ORDER NOW
- Air Flow: 110 CFM
- 3 Year Warranty
ORDER NOW
