*** The Official FIFA 13 Thread ***
Hit shoot or lob pass then pass straight after, can't really explain it more than that, you can use irections to fake shot turn etc.. Best bet is to try it in the arena to get your head around it, trying to do it in a match when you're not used to it puts pressure on your trying it, and also makes you not want to keep trying if it goes wrong/you get tackled/it messes up and leads to the opponent scoring etc.. :)
thanks tim will try it - if i cant do it ill just stick to my basic game :)
any tips about breaking through lot of defenders around box? I just seem to pass left and right and eventually give ball away :P
Sounds about right :D
Are you on xbox or ps3? I'm sure some people will be willing ot have some games & help you see whats going on/wrong whichever platform :)
You need to remember decent short passes will pass "over" the defender in the way.
They sort of chip it over the extended foot. Another way is to run away from goal and draw a few defenders out and turn back sharply sometimes opens up a hole.
In short players do different things so its just trail and error.
If none of the above try mixing it up abit by crossing a couple of times just to keep them guessing.
Hope that helps
I just generally see 4321 as a CCM for defensive, outside cm's for attacking & playmaking, and thats worked well on my other teams. Also its not really more attacking at all, you are losing a H/L and H/H for 2 H/M's who will roll back a bit more than Kaka did and not be as tired as Ramires ALWAYS gets within 10 minutes!
Whats wrong with Pepe? Granted, he's a homicidal maniac, but he is great in the air, good solid tackles, always in the right place, whatcha got against the boy? :eek:?
Kaka as a false 9 ST would work really well imho, I think Sonny used him last year as the same role and he provided good dispatch to the RF & LF, and in honesty, his finishing is on par with most strikers!
Pepe and Ramos I just don't like , I never got on with either of the last year either TBH.
As the CM's and work rates. The team tactic's override work rates or they do in my experience.
Setting defensive mind set even keeps Marcelo/Alves in check this year :eek:
could someone who has used both 4321 and 433 tell me which they prefered and why?
cheers
Topher
divaboy has replied to above, just looking for a few more opinions before I buy..
but either I guess I could swap in game, so it maybe which is the easiest to build a hybrid?
OMG just found the player i played against last night in my earlier posts on the EA forum. He called my play as boring and that i was a pace abuser because i have Nani, Wellbeck and Sturridge as my front 3. He also mentioned that i added more pace because my one substitution was Auyembang on for Wellbeck.
This would be fine in general except his team included:
Daniel Alves, Marcelo, Carlos Eduardo, Ramires, Bastos, Neymar, IF Natale, Muriel.
He then bought on 3 subs which were Lucas Moura, Pato and some other speed freak. But yeah i have the pacey team :confused:
You answered your own question when you mentioned he's from the EA forums :p
