- 25 Sep 2012
Hello all,
I'm planning on ditching my unreliable Corsair H100 (rattling noise despite diode fix) and doing what I should have done when I bought the Corsair - watercool.
I currently have an i7 2600k cooled by the H100 and a GTX560ti which I've mated to a Corsair H70.
The plan would be to buy an Overclockers V8 or V12 cooling kit and either a OcUK H20 GTX670 or HD7970.
The question is, could I run these together using just the one radiator for cooling (as in some custom builds I've seen) or would I need a separate radiator for the GPU cooling but on the same loop?
Would the triple radiator of the V12 kit be sufficient for both or would I be better buying the V8 kit and a separate single radiator and fan for the GPU?
Thanks in advance.
Rob
p.s. great site!
Thanks in advance.
Rob
p.s. great site!
