Value PC for accounting spec check
29 Jul 2011
Northern Ireland
The PC is needed to replace an old PC at my friend's work, he asked me for one, it's for Sage and HMRC. Is this the best value I can do? I'm open and very grateful for any suggestions :)
Microsoft Windows 7 Home Premium SP1 64-Bit - OEM (GFC-02050) £79.99
Intel Pentium G860 3.00GHz (Sandybridge) Socket LGA1155 Processor - Retail £59.99
**B Grade** Seagate Barracuda 7200.12 500GB SATA 6Gb/s 16MB Cache - OEM (HD-252-SE) £33.50
Imp MicroATX Tower Case (500w PSU)
£29.99
**B Grade** Gigabyte H61M-S2PV Intel H61 (Socket 1155) DDR3 Motherboard £26.00
Crucial Ballistix Sport 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (BLS2CP2G3D1609DS1S00CEU) £25.99
OcUK 24x DVD±RW SATA ReWriter (Black) - OEM £16.99
Akasa AK-CBSA05-50BK Super slim SATA rev 3.0 data cable with securing latches - 50cm, Black £3.49
OcUK Value SATA-II 90cm Red Data Cable (NLRB-307LOCK) £2.99
Sub Total : £254.12
(This can be changed during checkout) Shipping : £10.50
VAT is being charged at 20.00% VAT : £52.92
Total : £317.54
You could go lower with the CPU. The G620 is a great chip for about £15 less, and you could even go down to a celeron if you really want to save money.
Thanks, I'll keep that in mind, I wasn't sure about the Sandybridge Pentium/Celerons. I think I'll use the G620 :)
Primo TURBO" AMD Athlon X2 250 3.00GHz DDR3 Dual Core System [FS-310-OK]
£243.98 inc VAT
With OS it's £303, same price and Athlon x2 really doesn't match the Pentiums. Thanks for the reply anyways.
