Posting on behalf of a friend who's facing a bit of a dilemma.
He wants to spend approx £1800 on a MBP (15") but cant decide on the base spec Retina with RAM and CPU upgrade or the top spec classic with anti-glare and user upgraded RAM (and SSD eventually).
He's worried about the performance difference between the 512MB GPU on the base Retina compared to the 1GB on the classic (as the 1gb on the up spec retina is out of budget)
So in essence it comes down to (with HE pricing)
Retina 15" - i7 2.6Ghz, 512Mb GT650m, 16GB Ram, 256GB SSD for £1749
or
Classic 15" - anti-glare screen, 1gb GT650m, 750GB 5400 HDD, 8GB RAM for £1597
and then upgrade the RAM and HDD to 16GB and SSD for £1800 ish
so in essence, it comes all down to the GPU (the screen difference isnt much of a big deal, so we can ignore that)
thanks for the advice!
or
