You want to purchase the oem paste and pads? I don't think they are available to buy.
I used MX-4 and some EK thermal pads(1mm) from a specialized watercooling shop(can't link - competitor)
What's the correct way to apply the paste, a small dollop, or spread it?
Well one thing to note is that that it wouldn't matter if the pads were too thick, as the pressure from the screws holding the cooling plate down would squish the pads anyway.
With AMD GPU's i just pea-dot and let the cooler spread it
With nvidia gpu's i spread it with a bit of clean plastic to make a tin layer all over
I dont know if those are optimal, but they havent failed me yet![]()
