7970 out of memory error
15 May 2012
Louth, lincs
just had a crash and got this
so whats that mean????
Playing bf3? Disabled your page file? I used to get that when i disabled my page file or the page file i had was too small.
13.1
just looped heaven on extreme, with cpu at stock and gfx at stock and there is a definate jerkiness about it.
max temp on gpu 42c after 25mins of heaven
13.1
Wind up the speed on the CPU, heaven likes high CPU speeds. It could be this causing the jerkiness.
Ok will try, thx
Just found this
Windows vista/7 32 bit only
* In Windows 7/Vista go to Start menu. Go to Accessories. Locate the command prompt shortcut and hover mouse over it. Right Click on the shortcut then select Run as Administrator.
* In the command prompt type this exactly: bcdedit /set increaseuserva 3072. Then hit enter.
* Make sure you get a message back confirming the change was made. To verify the entry is there you can type just bcdedit, hit enter, and you should see the entry now listed.
* Then close the command prompt. You just told Vista/ to increase user virtual address (userva) space to 3072MB.
* Changes take effect on reboot
What about 64bit??
Apparently worked for 1 guy
This sounds more like it another answer to the same problem
Hi Olivia Aust,
That means you have lack of virtual memory, you have to add some more virtual memory by right clicking My computer, properties, advance system settings, then click the advance tab, click the settings under performance then advance again, under the virtual memory click change then add your desired size of memory depending on the free space of your hard drive, click ok, ok again and restart the computer before it take effect. You can also add GPU memory in CMOS setup.
Edit. In otherwords the page file, lol, well have increased it and will see how i get on but that will be tomorrow now.
