- 28 Jul 2003
- South Wales
Everyone is a comedian! Useful advice from the motors section yet again
I see Bennie's point, It's difficult to just pin this on cold and short journeys. Typically, if a battery has dropped a cell because of the cold, no amount of topping up / recharging will ever see it fully come back to life. If your battery has dropped because you left the interior light on (for example) then that's a different scenario all together and a good charge / jump / run will see it right.
bought a ctek5 over the weekend and its a nice bit of kit.
BTW, I wasn't joking about the Lidl charger, they sell a proper smart charger which is excellent value.
Lidl do a pretty decent charger for not a lot of money. You can find them on the shelf just down from the horse burgers.
How can I test if its got a dead cell?
MG owners quote
AGM batteries help as the glass sandwich mats prevent deep discharge plate warping causing a short between the plates
You don't need a CTEK, you are putting charge back into a discharged battery, not flying to the moon.
The Lidel one is fine, a £15 12v@6A jobbie from ebay is also fine.
Save your money for a new battery (if required)
If you have masses of disposable income, buy a CTEK, that is why they exist.
Yes, if you have a car sitting there doing nothing for weeks on end, then an intelligent charger is ideal, a normal charger left on too long will overcharge the battery.I get where you're coming from but reading other threads on the cteks they have conditioning type program's?
If you just have a flat one, anything that can supply 13.8 volts for a few hours is all that you need. Just turn it off when it is done.
I had looked at those. It seems the 3.6 models top end is a little close to my battery requirement so looked at the 5. It's 65quid tho so wanted some advice before committing
Cheers, will check it out
