I suspect you're referring to me.
What do you mean by "fats the body can't get rid of"?You do realize that saturated fats are the bodies preferred choice of energy don't you? It is just as easy for the body to produce energy from dietry fat (especially saturated fat) as it is from carbs, or I should say it's just as easy/efficient once the body has adapted to primarily using fats for energy as in a ketogenic type diet, which I follow.
Sustained excess calorie intake causes storage of body fat not the consumption of dietry fat, body fat gain is more to do with calorie intake vs energy expenditure. My saturated fat intake is high but carb intake very low, so ratio of calorie intake vs energy expenditure is still well in balance, if there is a slight imbalance it's usually expenditure is higher than calorie intake, appetite tends to be lower on keto type diets, not sure why this is but I often under eat as a result.
Yeah I eat a lot of butter, at least 6 tbsp a day and the same amount of coconut oil + olive oil, cod liver oil + the fat on whichever meat/fish/poultry I have. It's great, keeps me lean & mean.
My waistline after years of very high saturated fat consumption
I don't eat cornflakes due to my dislike of processed/junk food.![]()
I probably worded that a little wrong so i apologise, my point was that by consuming any excessive amount of a particular food type you increase the caloric intake regardless of how healthy it is, this will cause you to gain fat whatever happens unless A. as you say, have a diet in place that allows for the extra calories or B. exercise like a fiend.
You obviously have a balance in place but for 99% of joe blogs a slab of butter with every meal would cause them serious problems and im a great believer in butter.
In all honesty i did expect you to be chubbier
