Man of Honour
- 8 Nov 2007
- Outer Space
Looking good so far, only thing I'd consider is a bigger rad or add another one, as a general rule a lot say 120mm per component cooled plus 120mm, so 3 components (GPU x2 + CPU) is 120x3=360 + 120 = 480. Just a rule I've gone by, but maybe wait to see what others say, PGI is good on these things
Tubing, I'm using it and it's nice quality, Mayhems recommend Clearflex 60 but OCUK don't stock it, but they also say XSPC is cool too
Also, make sure you get some angled fittings, some 45deg and 90deg ones, you'll thank me later
Hope this all helps?
