Asus rog matrix platinum settings
Very nice Rossi
The graphics card look great.:D
One of the advantages I have found using a H100 is the high air flow compared to a custom water loop. This is very helpful when using graphics cards with a cooler that pushes the heat into the case. On my other rig my H100 does a really good job removing all the heat my nvidia cards produce.
@weehamish
As promised
http://imageshack.us/photo/my-images/507/40212956.jpg/
This is about as tidy as I can get
Yes
Old farts like me like our antiques.:D
Why would any one want to pay £39.99 for (for example) NFS MW on Origin when they can get the discs on Amazon for £20 delivered?
I still buy nearly all of my games on media, it's cheaper and you get something to show for it :)
I am lazy and buy from Steam. So much easier :) If I need to install windows, I will have to connect up my DVD drive though :(
@Kaapstad,
Smart setup, but, you really need one of these to finish the job:
Cost £6 for both delivered iirc, if you can't find them, pm me and I can point you in the right direction.:)
Before anyone jumps in to tell me I only need one bridge, yes, you do need two bridges for 7970/50 CrossFireX.:p
@Kaapstad,
I think your right
I have just glanced at my nvidia cards and they are connected with the SLI version so I will definely have to get the Crossfire version so they match.
Much better Kap, job done!:D
Those brown jobs are sooo ugly.:(
why would u xf a 7970 and 7950 though? Its kinda like wasting £100 lol?
Because my setup@1100MHz won't be much slower at all than any other 7970 CrossFire setup@1100MHz, while costing £500, you do the maths.;)
It's not going to set any BM threads on fire, but in games, it's no slouch either.
I bought the 7950 because it cost me £200 from a friend that thought tri-fire was worth a punt but just settled for CrossFire instead as it was more than capable.
I'm a 3D user and some titles can do with the extra grunt, while others have negative scaling in 3D, so I saved myself about £150 by getting the 7950 instead of a 7970 and not getting severly burned in the pocket when only one gpu is pushing a 3D title that doesn't like CrossFire.
I suppose so lol, you can say your wasting 100 quids worth of card or saving 100 quids worth by not saving 2 70s.
I still wouldn't mix and match but that's just me lol.
