26 Jan 2013 at 13:38 #21 Winston Winston Associate OP Joined 19 Oct 2002 Posts 2,120 Location Chester - a.k.a Gh0sTf@cE Nickolp1974 said: still primming at mo, had to knock vcore up notch Click to expand... Cheers fella The bottom two settings that are at 5 are needed for stability
26 Jan 2013 at 13:43 #22 Nickolp1974 Nickolp1974 Soldato Joined 15 May 2012 Posts 5,920 Location Louth, lincs Nearly there with initial stabillity testing, and i'll give em a whirl
26 Jan 2013 at 13:50 #23 Nickolp1974 Nickolp1974 Soldato Joined 15 May 2012 Posts 5,920 Location Louth, lincs Looking at your volts there, is imc voltage same as IO? If so thats really low, mine on auto reads around the 1.25 mark
26 Jan 2013 at 13:52 #24 Winston Winston Associate OP Joined 19 Oct 2002 Posts 2,120 Location Chester - a.k.a Gh0sTf@cE Think that's different depending on the mobo, mines on auto
26 Jan 2013 at 14:26 #25 Nickolp1974 Nickolp1974 Soldato Joined 15 May 2012 Posts 5,920 Location Louth, lincs On cpu tweaker the round trip lat, with a value of 32, whats that in the bios??
26 Jan 2013 at 16:16 #26 Nickolp1974 Nickolp1974 Soldato Joined 15 May 2012 Posts 5,920 Location Louth, lincs Not having much luck The pub is beckoning now! For tighter timings do i need to touch vcore at all?
28 Jan 2013 at 20:11 #27 8 Pack 8 Pack OcUK Staff Joined 20 Feb 2012 Posts 10,163 Location John Smiths Stadium Nickolp1974 said: Looking at your volts there, is imc voltage same as IO? If so thats really low, mine on auto reads around the 1.25 mark Click to expand... 1.25v on I/O is High for 2400 ish. Try 1.05v for starters.
