- 11 Mar 2008
I'm looking at server options for a client just now and could use some advise.
This is a replacement for an existing live server that is due for replacement. The server will be running SQL Server, will have approx 6 DBs to run, with the largest being around 50GB in size currently (the others range from 1GB to 20GB at present). The database get's hit heavy during peak time (which ranges from 9am to 8pm).
We are intending of getting 4 x "Dell 200GB SSD SATA Value MLC" in RAID10 configuration (not bothering with the SAS versions of the drives, which come in at almost 3 times the price of those ones!!). This will have the OS and the SQL Databases on it.
Does anyone have any experience with Dells SSD drives? If so, any information on their reliability and performance?
As for the RAID 10 - does anyone know if this operates using TRIM? (will be using Windows Server 2012)
I know I could ask my Dell contact this, but it will take a while to actually get a proper answer (and I'll no doubt have to explain it 6 times as usual!)
We'll also have a couple of 2TB HDDs in to handle backup files and other misc bits and pieces.
