i3 2120 will it be holding me back? (7850 GPU)
Caporegime
13 Jan 2010
Llaneirwg
Evening guys
My HTPC has become a gaming htpc and i didnt quite the gpu i would end up having.
is this [EDIT] CPU likely to be holding my back? The question being should i change it for something else? ( i dont want it to be hugely power consuming at TV watching only time)
GPU is on its way to replace a 6950
Games so far include
Fall out
Portal
Crysis (not expecting miracles)
Half life
I don't have many games yet as i don't play on line, single player gems only come out once in a while
And basically anything that is single player orientated that is controller friendly.
I understand these aren't new games but if I buy any more on steam it will likely be on both my main rig and htpc
not civ and not rts, not really controller friendly, also these aren't plasma friendly
Res is 1080p as it's connected to plasma.
Most of the games you mention are fairly low powered and were around at the time of E8400 and GTX280 or even earlier.
Your GPU will be a fair bit quicker than a GTX280 in most games (it's a few generations later, the equivalent AMD at the time was probably a 4870). The GPU won't be the problem in your build - don't worry about it.
Your CPU will be a bit quicker in most games than an E8400, although not by as much.
The point being that the E8400+GTX280 combination got reasonable frame rates (mostly 60+) in games from that era. Here's a comparison of an i3 2100 and 280 vs E8400 and 280 on some similar games. The 2100 is slightly slower than your CPU.
http://www.anandtech.com/bench/Product/56?vs=289
As you can see, Crysis Warhead, Fallout 3, Far Cry 2 are all reasonably good (40fps+) on a slightly lower resolution than your 1080p - you can expect AT LEAST this performance. If those frame rates were GPU bound, you'll get better than those shown. If they were CPU bound, you'll get about the same.
So there's really three answers here
1) Will you get decent frame rates?
Yes, in most games. CPU bound new games might start slowing down, but anything more than a year or so old, or which are moderately taxing on the CPU should be fine
2) Will your CPU hold you back?
Probably not, but if you do play any games which start slowing down, your CPU is likely going to be the first component to start causing a problem - it will bottleneck the graphics card, if you hit the point where you're maxing the CPU... which is, as I said, unlikely with the games you're mentioning.
3) Will your GPU hold you back?
No. It won't handle the best newest games on max, but your CPU will cause problems long before your GPU does.
My advice is to just start playing the games you want to play, the ones you're mentioning should work fine. If you get into a newer/more taxing game (Crysis 2, Rome 2 Total War etc) and start hitting a problem, keep an eye on CPU+GPU usage to see which is the problem. Chances are it'll be the CPU causing the problem, and you can just sell it and drop in a faster i3 or an i5. Most games are biased towards the GPU anyway, so you'll probably get away with your CPU for a while longer.
What is the usage of your CPU and GPU when playing these games that you seem to be struggling with? If your CPU is saying 100% on both cores, i would hazard a guess the CPU is bottlenecking your newish decent graphics card.
He's not had a chance to test it yet, the 7850 is en route to him now - the point was that he's asking us whether he should replace the CPU while he's upgrading the GPU.
Yeah i got that a bit too late i was just answering to the title of the thread. :p
Tbh he just needs to test it himself when he gets it and see if runs ok. What i said before is still relevant them checks will help him determine whether or not he needs to upgrade the CPU now.
GPU ordered is a great little card no problem there.
mistake in the opeining post spotted!
i was asking to change CPU not the GPU! brain freeze.
the new GPU is in, the main reason for changing the gpu wasnt performance it was heat. The 6950 just got to hot, even when idle. the fact it goes from pci backplate to front of case (effectively cutting the case in half). so much so the cables for the motherboard had to go under the gpu
the i3 was bought no really expecting the HTPC to become a gaming HTPC to this extent.
I actually tried crysis the other day and on high settings it seemed fine. (i didnt get far through) and this was on 1080p, also this was tested with the 6950
EDIT: just for interest, what would be the best CPU upgrade on a H61 board? (which i gather offers no overclock)
A I5 Sandy or Ivy (making sure it is compatible with your mobo, or flashing the BIOS accordingly), with good value and decent default clocks. Maybe worth looking for a second hand one.
I'd just go with the 3570K (at £160 or there about, no contest), or a second hand Sandy. For £20 between a 3570K and a decent locked processor, it's worth the extra (at least better resale value). Provided of course it is compatible with your mobo.
