Can't get into bios on Gigabyte z77-D3h
5 Jul 2012
When I turn on the PC the splash comes up but its really zoomed in so its only a small part of it showing.
And no matter how much I hammer the DEL key it still just boots straight to windows?
I had a similar problem but thankfully it worked after a CMOS clear.
Do you know what may have caused the problem and was it fine before?
I am having a similar problem, since this morning my PC doesn't show the BIOS screen or Windows loading graphics and the monitor only comes out of standby when Windows has loaded to the login screen.
Am weary of doing a CMOS reset in case I cannot enter my overclocking settings again but it might be the only way to proceed.
What do you think?
If I remember correctly, I was reinstalling windows 7 onto it and while I was installing the amd drivers the computer froze up and I had to hard reboot.
I went ahead and CMOS reset mine, now can't get anything on screen. Its a new motherboard time for me ;(
Ah well I knackered the USB 3 ports on this one anyway..
It did it again went I went to start it this afternoon.
However taking out the hdmi cable from the graphics card let it start as normal?
Prehaps a graphics issue?
