They posted this newer comparison recently:
It does not use xsplit.
Thanks CAT.
It is pretty subjective actually, there are situations when Intel is better than AMD or AMD better than Intel.
So it depends on what you do, and you can never have the best of both worlds.
But i completely agree with them, if you have a top of the line GPU and CPU from either camp you don't play games at reduced settings 1080P if you can get good frame rates at high settings, thats what such GPU's are for.
And you certainly don't play at 800 x 600 or 1280 x 768, to often i see so called reviews like that and i'm left thinking "well that told me absolutely nothing at all, what a complete wast of my time"
And they are also right that the amount of games some reviewers test is shrinking, to the point now where some are left with just 2 of the same games they have already been using for many years, one or two extremely well known reviewers selection of CPU benchmarks is pretty bleak, photoshop CS4 (which no one has used since 2007) Cinebench and WoW and a handful of synthetic benches, no information there at all.
And forums, how many times do you see people recommending Pentium G chips over FX-4's and mid range APU's?
Look at the state of this...
http://techreport.com/review/23750/amd-fx-8350-processor-reviewed/7
Even with higher FPS than AMD's low end CPU the Pentium G is a stuttering mess by comparison.
http://techreport.com/review/23750/amd-fx-8350-processor-reviewed/8
There is no place for a Pentium G in any rig remotely for gaming at all, your better off with a cheap AMD.
IMO same goes for the 2 thread i3's, in games that use and need a lot of threads the i3 will grind and stutter along just the same once online.
While i do think the FX Piledriver chips compete well with current i5's / i3's, and are a real alternative. I don't think that AMD's current line of CPU's is great and think it could be better.
But i also think some reviewers really need to get out from under Intel's skirt.
'If' and as AMD manage to improve upon their single core IPC in the near future; this argument will start to heat up to thermonuclear levels and become increasingly ridicules in some quarters, which i suspect some reviwers will become increasingly less relevant, loosing the plot more and more.
