Pertetual motion item
6 May 2009
Does anyone know where I can buy a good quality perpetual motion 'toy' these are the things that use kinetic energy to move and balls spin around each other. Similar to Newtons cradle.
I have seen one on a US website and are called 'Space balls' but its only cheap and runs on battery power. I have always wanted one but never thoight to look for one
That isn't perpetual motion. There is friction between the moving parts and with the air therefore energy is lost. It will stop eventually.
OP, if you have a cat and some buttered toast you can make one:
Not quite, a dead cat doesn't always land on its feet.
At the speed the cat-buttered toast combination would be spinning, it would be impossible for the cat to consume enough sustenance to survive.
Unfortunately, the cat would die, and the laws of thermodynamics will reign once more.
What you fail to realise is that it doesn't stop... Well it does when the 9v battery runs out that's in the bottom of the thing..
I've got one. :D
That would be catastrophic.
Actually, the entire argument there is based around both items falling, however, one they are attached to the motor they are no longer falling so no need to spin. :p
But if they don't spin, then there is no power generated?
Thermodynamics wins again :mad:
you can get clocks that run on temprature change/air pressure
I'm sure someone could make a toy to do the same thing but i'd imagine it would be stupid expensive just like the clocks are
