Hello
I am looking to get in to pc gaming and need to build a new rig, and need some advice on parts that would work well. My budget is around £400-450 including a OS.
The parts needed are: CPU, mobo,ram, case, GPU,PSU, optical drive,HDD and OS
I am looking to build a intel rig, and use parts that allow upgrading and can be used in future build if possible.
I was looking at the pentium G and the i3 3220, with either a 7770 or 7850. But not sure which will give the best performance for the money, are these a good combo or should i go with something else?
thanks
thanks
