Hi
Title shamelessly stolen from another thread, but it's really getting to me now!
It's a 53 reg, 1.4 Golf Match, and it's been having idling problems for a while now. In fact I think I may have created a post on these very forums about it.
The fluctuating idle is ok, I can deal with it (idles between 800-1000 up and down) - however this morning the car wouldn't start. It would turn over, but not spark into life. I eventually got it to start by almost killing the battery. My cars done this before (couple years back) so I phoned the RAC, they came around, pushed the car a little, and it started straight away. I was told that it may have been flooded. (the previous night I had started the engine)
Fast forward to today and I did exactly the same thing last night. Started the engine once to see the mileage, switched it off again. This morning I go to start it, and it turns over but doesn't start the engine. I presume flooded again? I tried to push it a little, no luck...
There are also moments where the engine will stall or cut out just after I start accelerating. There have been a few times where I've nearly gone on to the other side of the road. It's pretty scary not having power steering as I go round a corner...it's getting to the point of being too dangerous to drive.
I also drive down a pretty long drive way, and at the end of it my car will tell me !Check alternator! - now I mentioned this to the guy at the garage and he said it's not the alternator, but just a generic message. "we can't find anything wrong with it"
Obviously I'll be taking it to the garage, but I'd like to try and diagnose the problem myself (with your help!) before forking out the money to a garage.
Thank you.
Thank you.
