Check with this: http://www.coolingconfigurator.com/
If it doesn't show any full cover blocks available then you may be out of luck on that front, though you can still use universal core only blocks if you so wish![]()
Both the same thing essentially, the swiftech kit has a pump built in to the radiator, the OcUK kit has the pump separate.
I'd go for the OcUK kit, better components and won't be a pig to upgrade at a later date.
My bad I haven't been following swiftech lately, got my info from an image search
@op sounds like you need to have a good read up on the finer details of a custom loop, get stuck finding some of the answers you require, give us a shout![]()
To watercool your gpu you would obviously need the block and x2 fittings, maybe another rad is you plan to push your card hard.
You won't need any more additional things for the motherboard.
You would need ID 3/8" OD 5/8" fittings.
Heatsinks are only required if you go with a core only block but fullcover blocks don't need them.
Ok thanks for that, but what is ID & OD ? Please excuse my noobyness! As I don't have a clue about water cooling.
Sorry but I would avoid Swiftech these days. In the UK, it's next to impossible to get spares or replacement parts so re-use is severely limited if you change any parts. They also had serious problems with quality assurance at times (badly anodized tops on the GTX block were ignored and the resulting galvanic corrosion blamed on not using their specific coolant - in the US some people got free replacements but these were not offered to overseas customers).
