Caporegime
- 29 Aug 2007
- Auckland
I want to smash my brain out with a hammer.
Be thankful you have one to smash.
There are still numerous points waiting to be debunked, not least the impossible transmission delays that have been conveniently ignored so far.
What was impossible about the transmission delays?
What was impossible about the transmission delays? The moon is a bit less than a light second away off the top of my head, isn't it?
See videos under point 9.
Currently about 3 mins into that first video under your point #9. The guy who made the video refers to an exchange between Houston and Michael Collins (who was orbiting the Moon in the CSM while Neil Armstrong and Buzz Aldrin were on the lunar surface). He says that Collins' reply came down the line too quick to have come from lunar orbit. On the transcript (page 392 in the PDF) that exchange takes several seconds, not the 1.07 that your Youtuber seems to think. Houston calls up at 4 days, 14 hours, 9 minutes and 18 seconds mission elapsed time, the reply comes down the line at 4 days, 14 hours, 9 minutes and 25 seconds MET.
Now, I'm just a gullible soulp) and I ain't no mathematician, but even I can work out that the difference between 4:14:9:18 MET and 4:14:9:25 MET is rather more than 1.07 seconds!
nearly. The moon is around 240,000 miles from Earth (it varies of course depending on it's current orbit) and the speed of light is 186,282 per second so you are looking at just over 1 second (1.3 seconds) for a one-way trip at the speed of light. But don't forget this is a two way trip, the radio waves are sent out, meet the spacecraft and then are sent back so actually you'd expect 2.6 second delay from the moon.
Wouldn't radio waves only travel at the speed of light in a vacuum and thus have slower time leaving our atmosphere and then back in etc. There is also some delay expected with processing etc.
Nope, newtons law pretty much comes in to play here, no extra gas is needed due to a lack of atmosphere.
The lack of air resistance would lead to dust falling quite quickly. Remember in a vacuum all objects fall at the same rate. That's GCSE level physics.
Clearance lot of dust? Dust is cleared. That isn't what you were saying earlier.
The moon isn't soft either, there's a thin layer of dust over a solid rock surface. No creator would be formed if that's what you are applying.
And no relative to vacuum, the rockets produce hardly any gas to suspend and push particles around, you get a small patch straigh under the thrust vector.
What was I saying earlier? I can't be bothered to check. I am just thinking that a decent amount of dust would be cleared. Not implying a crater.
Then how do you explain all the home equipment at the time used by various people like you and me all around the world picking up the broadcast signal's from beyond the Van Allen belt? There had to be people in the ships to speak and respond to questions and anyone with a HAM radio which was common at the time could pinpoint the position of the spaceship and listen in. There is just no way to fake that. Most of those people had no link to NASA as they are people like you and me.Because they couldn't get through the Van Allen belt and still can't.
The most compelling evidence to refute that the moon landings were faked in my view is the sheer amount of people who would have been involved, physicists, investigative journalists swarming around, etc - there's just no way all these minds would have been fooled, or that no one would have found out or breathed a word. Utter nonsense.
As for the radio transmissions, as already posted, go read the transcripts. It's more stupid youtube videos. It's yet another one which has been debunked a million times. For a weeks research you got most of the info from the same place, was hopping you would actually post something new.
What makes you think that?
Moon = their layer of regolith over solid rock
Moon = no atmosphere
Moon = 1/6th mavity
Put those three together and you don't get large dust movement at all. There's nothing to compound the affect of the rocket (no atmosphere), low mavity means low thrust, thin layer means not much dust anyway.
