**Today Only 29/01/2013** KFA2 GeForce GTX 660TI EX OC & MSI HD 7970 Lightning BOOSTED Edition
22 Aug 2010
More huge savings today on two top products.
KFA2 GeForce GTX 660TI EX OC 2048MB GDDR5 PCI-Express Graphics Card @ £224.99 inc VAT
The KFA2 GeForce GTX 660Ti graphics card adds a new dimension to the game-changing NVIDIA Kepler-powered family. Delivering the ideal combination of performance, power efficiency and affordability. It's a must-have upgrade for today's hottest and most demanding games.
Specification:-
- Core Clock: 1006MHz (GK104)
- Core Boost Clock: 1084MHz
- Memory: 2048MB GDDR5
- Memory Clock: 6008MHz (Effective)
- Memory Interface: 192-Bit
- Processing Cores: 1344
- Shader Clock: 2012MHz
- Bus Type: PCI-Express GEN 3.0 (Backwards compatible)
- Display Connectors: 2x Dual-Link DVI-I, 1x HDMI 1.4a & 1x Displayport
- SLI Ready (Upto 3-Way SLI Supported)
- HDCP Capable
- DirectX 11 Support
- OpenGL 4.0 Support
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- NVIDIA Surround Enabled
- Lower power consumption (Maximum consumption 170 watts at stock speed)
- 1x 8-Pin & 1x 6-Pin PCI-E Connectors required
- TDP: 150W
- Warranty: 2 Years
Only £224.99 inc VAT.
ORDER NOW
<img src="http://marketing-uk.msi.com/images/ocuklightning.jpg" alt="Lightning" width="780" />
Key Features
Unlocked Digital Power
- Unlocked BIOS: One click to unlock all protections for extreme overclocking
- Digital PWM Controller: More stable and precise voltage by digital signal
- Enhanced Power Design: 2X Power output for maximum OC potential
GPU Reactor
- An add-on device on the back of R7970 Lightning (Behind GPU) for the overclocking stability
- Provide 88% higher power capacity and eliminate power noise (ripple)
Xtreme Thermal
- Dust Removal technology on Twin Frozr IV keeps dust out for the best thermal condition
- Dual Form-in-one Heatsinks provide better heat dissipation and strengthen the structure
Military Class III Components
- Meet MIL-STD-810G standard to ensure the best stability and quality.
- Adopt CopperMOS, Hi-c CAP, Golden SSC, and Dark Solid CAP
Specifications
Graphics Engine ATI Radeon HD 7970
Interface PCI Express x16 3.0
Memory Type GDDR5
Memory Size(MB) 3072
Memory Interface 384 bits
Core Clock Speed(MHz) 1070
Boost Clock Speed(MHz) 1150
Memory Clock Speed(MHz) 6000
DVI Output 2
Mini DisplayPort 4
HDCP Support Y
HDMI Support Y
Display Output (Max Resolution) 2560x1600
RAMDACs 400
DirectX Version Support 11
OpenGL Version Support 4.2
CrossFire Support Y
Card Dimension(mm) 305x135.5x40mm
Warranty 3 Year
Only £347.99 inc VAT.
ORDER NOW
Fastest single gpu on the planet for under £350? Damn that's cheap.
I can't see how this would be faster than a 670 with the same clock speeds:
http://www.overclockers.co.uk/showproduct.php?prodid=GX-195-EA&groupid=701&catid=1914&subcat=2294
http://www.overclockers.co.uk/showproduct.php?prodid=GX-018-KF&groupid=701&catid=1914&subcat=2294
....it's just occured to me that this may have been a typo, and you meant £250 :p
EDIT: I'm a dumb fool (self inflicted personal attacks are ok, right? :p ), cheers PaulyD
Get a 7950!
I though I would give a go with a 7850 ya know , But lol since i put it in , ive had issues with BSOD and some random freezing too.....never had anything like that with the Nvidia 560 i had :)
so i may well send it back and swap it :)....and give ATI a miss
I think the HIS HD 7970 X Turbo is a little bit faster than that.
the top 3 7970 atm are:
HIS HD 7970 X Turbo
GPU Boost Clock: 1180 MHz
GPU Base Clock: 1120 MHz
Mem Clock: 6000 MHz (1500 MHz GDDR5)
ASUS HD 7970 Matrix Platinum
GPU Boost Clock: 1100 MHz
GPU Base Clock: 1050 MHz
Mem Clock: 6600 MHz (1650 MHz GDDR5)
MSI HD 7970 Lightning BE
GPU Boost Clock: 1150 MHz
GPU Base Clock: 1070 MHz
and yes.. the price is really good!
Haven't paid any attention to the x turbo tbh, appears I over looked it :)
Though from a brief look I can't find stock of it anywhere.
So I retract my earlier statement :o
So I ordered the MSI 7970 Lightning BE yesterday on the promo deal and it has arrived safe and sound today.
There doesn't seem to be any mention of the Never Settle promo for the free games anywhere. It is a bit surprising as every other e-tailer has this offer for new AMD 7950-7970's and I though it was 'standard issue' so to speak.
Probably my fault for not checking prior to ordering but this makes the deal considerably less value when you factor in the resale value of the game bundle.
A little disappointed to be honest :(
Edit: reposted this in the graphics card section - probably best there in hindsight.
2nd Edit: Fantastic Customer Service OC's - promo code is in the post after emailing CS. Many, many thanks!
