Road Cycling Essentials
Status
Not open for further replies.
Are Crud RoadRacer mk2 the best mudguards for road bikes without mounts?
They give the best coverage but are very flimsy, also they won't fit if you have small wheel/frame tolerances.
Raceblades will pretty much fit anything, are a lot more sturdy, and will detach/reattach without much faff, but coverage is much worse even on the "long" version. They don't cover your front mech/crank, or your brakes so you will get a lot of muck build here, also they wont protect anyone behind very well.
Neither are perfect, just wish someone would step up and take the bests bits from both as it should be technically possible.
i have them and they do keep the muck of you so they do the job! :) but at the same time they are quite flimsy and on my triban 3 front nose piece won't fit! but then again i can't see anything fitting there :) also you need to make sure you tighten the little bolts up as i've lost my front lower piece.
otherwise they are fine really.
This wind is getting ridiculous! I was down to about 12 mph on a flat coming home it was that bad.
Might sack it off tomorrow if it's the same :(
don't be a wuss! do it and shut up :D today was crazy windy i got to say.. but at least i had a mile of fun which is really rare(all lights green + no traffic) and averaged 22mph(for that mile lol), wish i could have more open space here lol..
Wife might be out tomorrow evening. Since the snow melted I've had a big push. 28 on mon, 31 last night, need 24 to get to 200. Given that I barely ever even cycle consecutive days to begin with, I'm finding it quite hard work! You were saying yesterday about how your average speed had been "only" 16mph but my goal yesterday was just to keep my average above 15, never mind any faster!
Get out and do it Pete or you're on hill repeats of the rake as a forfeit... ;)
Right! We (myself and some mates) have pretty much decided to go to Majorca and to either take our bikes or hire when we get there.
It's not really a cycling related question but have any of you guys stayed around the Alcudia/Puerto Pollensa area and can recommend a hotel?
Getting really excited for this. Just reading some of the info on cycling in Majorca is getting me giddy :p
I'm going to Puerto Pollensa at the end of March. This will be my 4th year there, it's an amazing place to cycle.
We're staying in the Pollensa Park hotel, it's nice enough and the all-you-can-eat buffet saves a fortune in meals because i eat about 3 times as much as normal when cycling all day.
We're renting bikes from ProCycleHire, it works out around the same price when you factor in the cost of taking your own bike on the plane and transfers and also saves a lot of wear on your drivetrain.
A lot of cyclists also stay in alcudia. It looks like there are plenty hire shops along the main street when cycling through, but i'v never stopped there. It's a big place, so i'm sure there are plenty of hotels as well.
Sounds like you had the wind behind you ;)
My cycle home is in a SW direction. Right into prevailing winds :(
Cheers for the replys guys. I've had the Roadracers before but the rear one killed itself in the back wheel somehow, wanted to make sure they were the best befor ei ordered another set.
funny you say that but half that mile was in the back and the rest was facing it.. the wind today is not constant it was the gusts that made it hard to keep the bike in line! :) specially camden that was tough riding through it! i had to get of my saddle to keep the speed up.
Can anyone recommend me a turbo trainer?
I have recently broken my big toe and this seems like a good solution for me to keep exercise up whilst recovering.
I want to spend as little as possible really, but not to the point where I end up with a crap product, so still willing to spend.
Sorry to bring this back up, but does anyone have any thoughts?
From an initial look, the Tacx Blue Matic T2650 looks ok?
Thanks, I'm quite capable of searching myself, I was hoping for some educated advice....
Budget? If you can afford it, I can highly recommend the Kurt Kinetic Road Machine. V good road feel plus a good power curve that works well with Trainer Road.
No real budget, but want to spend as little as possible without ending up with a shonky product. I guess around the 100-150 mark, but less if possible. That looks to be fairly expensive.
I was thinking the same... After 3 months not cycling, 3 days in a row is already killing me :( ridiculous wind makes it feel like constantly going uphill!!
Don't want to wait until morning to decide though. Decisions, decisions!
Does anyone have any tips for turning right on busyish roundabouts? Even though I am cautious on the roundabout, I've found some drivers seem to just not see me and have to stop very suddenly. It's always the drivers that enter the roundabout just before the exit I need to take (so the entrance opposite to the entrance I took).
I've got bright yellow jacket on, and two bright lights which are angled down a bit so they are hitting the ground around 5-10m ahead so as to not dazzle drivers. Perhaps these aren't angled up away from the ground enough, but even at the angle they are at it is very bright to look at.
Any tips would be appreciated.
ok sorry, i used that, i clicked on the first link and read it almost got what they recomended but i bought Rollers instead to what rollers they recomended
Have you got anything reflective on? I have some retro reflective strips that I Velcro round my wrists at night which shine very strongly.
What's your lane discipline? Do you go round in the gutter the whole way? Or use the lanes like you would in a car? If the latter then all I can really say is make your move as soon as you pass the last exit, indicate profusely and be decisive, which is probably all stuff you know anyway...
Status
