Ok, so my question then is will 2GB of VRAM be borderline, enough, or more than enough to game on a single monitor at 2560x1600?
Will it also be enough to game on single screen 3D @ 1080p?
More than likely i will not be triple screening but go instead for a big projector screen 3D route.
i appreciate your help btw
edit: i should let you know that it will mostly be racing type and sports games that i play, so thats Dirt, F1, NFS, FIFA, NFL and the likes. Maybe a shooter but not really my thing.
It will be borderline yes but with "only" one GPU you're going to be needing to turn graphical settings down a touch to achieve playable FPS. By doing so - and also sacrificing MSAA where applicable - you will reduce the amount of VRAM used well away from 2GB.
With two graphics cards you've got more raw muscle to push higher framerates so therefore you can apply more settings. At 2560*1600 with 2GB you are likely to exceed 2GB if you apply max settings in certain games and with two GPUs you will have the GPU muscle to run these frame rates hence the recommendation for a 4GB card if you're going the multi GPU route.
For a single 1080p screen a single 2GB card will be fine. 3D doesn't use more VRAM.
Finding specific info on your own situation is difficult as not many people use 2560*1600 screens and those that do may play different games so it's a case of trial and error really but the advice above holds firm as a general rule of thumb. If you situation ends up different you always have the 7 day return period to return goods.
