 - 25 Nov 2011
 - The KOP
If that was the case they'd recommend everyone use v-sync. Trust me v-sync causes input lag whether you notice it or not is a different story.
They is a big myth that vsync gives input lag. But the truth be told we all get affected diffidently. Its not just switching on Vsync will make you notice input lag, they is also input lag in the Monitor you use the Mouse and Keyboard you use.
No one setup will be the same and your display is the main thing you should look at when you notice input lag.
This is one reason why when I picked my LED/LCD TV I went and looked at reviews and them testing input lag and at the time my Philips TV was reported the fastest input and response time. input of just 12ms and a response time of 2ms.
So when someone says they dont noice input lag from vsync remember its not just Vsync
 One things for sure it lowers temps a bit more lol.
