AMD Catalyst 13.2 Beta4 Crysis3 50% boost
Gonna take more than a 50% boost for me to download Crysis 3 again, grabbing the drivers though :p
Lol these I see no difference from last driver.
Still Frame rate drops.
Oh i am, i never did run it with 4x MSAA on 12.11 or 13.1. but i tell you what, vs 13.2 BETA4 even without MSAA my average FPS has gone up 8%, from 68 FPS to 73 FPS. (All High + 1x SMAA)
I did run it; All High + 4x SMAA on 12.11 and 13.1 and it was unplayable... i'm going to test it again now. :)
But yes, the sharp frame rate drops are not good, that needs to be better, its no good running around getting 80+ FPS and then your hit by someone and it tanks as low as 40.
Ok..
All High + 4x SMAA: 48 FPS Avrg
All High + 4x MSAA: 47 FPS Avrg
I don't know how much an improvement that is, as i say i did not test with 12.11 and 13.1, but whatever it is its a vast improvement, its actually playable with 4x AA now, with the older Drivers i don't think the frame rates got much over 30, if at all.
(7870 @ 1140 / 1450)
(P-II x6 1090T @ 4Ghz)
Ok..
With the leaked 13.2 i got around 17fps when i switched to 4xmsaa.
the 13.2 beta4 for crysis give it the performance it should.
On very high 4xMSAA close to 60, but as other mentioned bad framedrops still.
(i5 2500k 4.5 / 7970- 1050/1500)
Just installed these with my new 7950 that returned from RMA, thanks for the slightly free upgrade to the FLEX boost model OcUK ;).
Ran a couple of benchmarks and I'm already seeing some improvements from these compared to the 12.11 beta. Will probably give DOTA 2 a go on it seeing as my friend gifted me a copy.
Also just noticed CCC looks a tad different under the 3D application section :o.
