fx4100 throttling back
Ok so i can stop this with software so the board is indeed in need of a new bios update.
Hopefully they release one soon.
How did you resolve it bud?.
My OC throttles like hell underload and the only way i resolved it was to install AMD Overdrive - Enable Turbo Boost then disable it and click ok and then it stopped throttling. Definitely think it's a board/BIOS issue :(
THIS!!!
That's exactly what my FX6300 was doing I overclocked it to 4.4, the moment you run Prime it drops to about 3ghz I think it was, do the above and it sits at a rock solid 4444mhz
LOL really? I remember suffering from that issue when Phenom X6 was first released. :o
THIS!!!
Yep exactly the same here bud well annoying!
been like it for ages and I'm pretty sure I've got the latest beta BIOS :(
