Any Dremel experts here? Case cutting question?
Man of Honour
8 Nov 2007
Outer Space
Hi guys,
I want to cut a larger window in my case side panel on my Silvertstone FT02.
I've never used a Dremel before so I need to know what am I going to need? The case panel is either steel or aluminium if that matters?
Is the Dremel 3000 any good as I've seen it with a 15 piece kit for just under £40, would I need cutting discs as well and if so which ones please? (As much detail as you can give me would be great) :)
Not sure what else I need to do or know but feel free to enlighten me :D
I'm no expert but I've had some experience with the Dremel 3000, it's a really good rotary tool and I would recommend it however the discs it comes with are pretty crap, I used 3 on a 40x40cm window in aluminium.
The official dremel disc's (manufactured by dremel) are much stronger, got mine from BnQ.
Make sure you mask the panel to prevent scratches and cut on the inside of the panel rather than the outside for a cleaner looking cut.
Go slow at first just to score the metal and try to make many light passes with the dremel rather than trying to cut straight through on your first pass, the discs will last longer and the cut will be more accurate, it'll also help prevent the dremel from getting stuck or flying out of control.
Wear safety glasses! when those cheap discs shatter you don't want part of it in your eye :/
look here: http://forums.overclockers.co.uk/showpost.php?p=18875071&postcount=30
+1
the dremel carbon fibre cutting discs are fantastic
+1
i also have a respirator because you REALLY dont want to be breathing in those fine particles of metal and paint
before i got a respirator i was coughing for days afterwards, eyes watering, black snot... :(
Thanks chaps, really useful, think I'm sorted based on what you've posted :)
I only need a square-ish hole that is larger than what I have now, just to show off more of my modded internals :cool:
On an FT02 the front, base and back of the case is one large aluminium "U" shaped piece curving underneath the bottom fans. The rest of the case - including the side panels - are steel.
The standard window in the FT02 windowed side panel is pretty big and I am intrigued that you want it even bigger. I suppose if you wanted to show your drive bays internally you could extend it but... drive bays aren't exciting really. Is it watercooled?
Hi Jaybee,
Yep, watercooled and my drive bay has been modded and painted orange to match my orange theme, so it'll look rather nice ;)
Thanks for the info too :)
