In stock though?
My wife has the 4x and I've extensively played & messed around with it so I've made a pro's and con list for ya based on my hands on and the wifes comments.
Pro's
> The screen is jaw dropping. I much prefer IPS panels to the SAMOLED on my Note. Colours are rendered beautifully and not falsely over saturated and its a lot better outdoors than my Samsung
> Build quality is very good.
> It sits really nice in the hand
> Micro SD slot
> Its very cheap for a quad core handset
Con's
> The radio (as in mobile reception) doesn't seem as good as some other handsets. We are both with EE and in strong signal areas hers has been known to show very weak signal where mine show a full H+. It also performs very poorly in low signal areas and really doesn't hold on when you are in a 1 or 2 bar area. This is the wifes biggest gripe with it as where she's works is not well covered.
> No Jelly Bean (so no project butter) and LG still have'nt confirmed whether or not its getting it. LG's history of software support is quite poor.
> Battery life is poor. Standby times are ok but once in use you'll struggle to get a day out of it.
> The camera is quite poor particularly for video.
> It takes ages to charge up, no idea why.
Hope that helps
