Morning all. I have a 2006 MX5, which although still has a good condition interior, is starting to show it's age a little on the steering wheel.
I'm guessing the previous owner wore a ring, as there's a couple of scuffs and scratches I'd like to try and neaten up if I can. They aren't that easy to notice, but you can feel them sometimes as you pass the wheel through your hands.
Does anyone know any good leather treatments I could use on a steering wheel? Bearing in mind most of them explicitly state that they shouldn't be used anywhere you need to grip. I have AutoGlym Leather Balm which is nice on the seats, but makes them slippery - not something I want on my wheel. I do use AutoGlym Leather Cleaner on the wheel - it's just a spray cleaner, and that doesn't make the surface slippery, but it doesn't condition at all, only cleans.
I've taken some pictures below - bear in mind the flash makes the wheel look a lot worse than it actually is, but you can see the biggest problems.
There's some scuffing in the centre of this image, just on the outside edge of the wheel at it's lowest point.
This one on the top in the centre is the most noticable.
Not sure I can do anything about the wear on the joints of the wheel.
Any ideas gents? I know some people have had their wheels retrimmed, but I'm not sure I want to go down that route yet.
