Graphics Cards Advice.
4 Aug 2011
Hello OverClockers.
I am asking for some advice, about a possible upgrade.
My dad wishes to invest in a new GPU, more likely a new AMD 69** or 78** series card, utilizing the PCI-Express 3.
He has been looking at the following cards:
AMD 7850 1GB
http://www.overclockers.co.uk/showproduct.php?prodid=GX-306-SP&groupid=701&catid=56&subcat=411
AMD 7770 OC 1GB
http://www.overclockers.co.uk/showproduct.php?prodid=GX-293-SP&groupid=701&catid=56&subcat=1699
His present system specification is:
Enermaz 550W PSU
DFI LanParty NF4 (PCI-Express 1.)
ATI X1800XT 2GB
AMD X2.
2GB RAM.
However my concern is he will be connecting it to, an old PCI-Express bus system, will they be compatible, or does he have to look at much older graphics cards? :confused:
Don't bother with the 69xx cards now. You're far better off with the newer 7 series if you want AMD.
7770 isn't worth touching, nor is the 1gb 7850. Find the extra beans and get a 2gb 7850 mate.
As for compatible? I highly doubt it.
Mostly because DFI are no more so there won't be any bios updates. I think it may finally be time for you to buy a new PC tbh.
As above anything decent will be heavily bottlenecked by that rig. Without upgrading it a 7770 is about as far as you'd want to go. Anything more would be wasted. It's seriously time to think about a whole new system.
Thank you guys, for your responses.
I thought as much, that the CPU/RAM would be a series bottleneck to the system.
Yes it was state of the art 7-8 years ago, but that was then...
It might be time to adapt it to a home NAS system. :cool:
My question was more about compatibility however.
Would the new standardized GFX cards utilizing PCI-E 2/3 Standards actually work in a 16X PCI-E 1 motherboard?
ie, get enough power via motherboard, not be under-volt'ed?
The main reason for wanted a new GPU is he games on a Dell 2412M, an certain games are performing poorly.
I'll forward the suggestion, of investing in a new IvyBridge i5/i7 + Aftermarket Heat-sink, 8GB Ram, GPU, PSU.
After all he wants a new SATA3 SSD (after see'ing how mine loads windows :D ), an he was going to connect it via a PCI-E adapter card. :o
How compatible it is comes down to whether whoever made it bothers to put out a bios to make it work.
In theory yes, it should work. DFI have been long gone now though so they certainly won't be supporting bios updates.
It will be backwards compatible, but obviously a PCIe 1 slot isn't going to do anything for performance!
I always knew the older technology would have limited bandwidth.
Thank you.
Simply it SHOULD work, but it WONT, simple because they can't support the hardware. Many thanks guys.
Time for an upgrade then. ;)
Check out the Sandy Bridge Celerons and Pentiums. The Celeron G530 is a meager £30 and is as quick as a E8400 Core 2 Duo.
I had one and benched the crap out of it and it was a fighter lol.
You should be able to bag a board CPU and ram for under £100 easily. I was using a £30 MSI H61 board.
