Hi Guys
we now carry a full range of case lighting options from BitFenix.
The range features multiple lengths and colour choices that enable you to choose the best combination to make your casemod stand out from the crowd.
With the most intense LED lighting available, the Alchemy LED strips provide high intensity lighting to any case so that you can showcase your awesome hardware easily.
each kit is interchangeable and expandable too meaning you can add more kits and change your colour scheme.
with high strength adhesive pads on the rear of each strip, they are easy to fit and look superb.
View the Full Range HERE
Here are some standout products from the range:
BitFenix Alchemy Premium Modding LED Strip - Aqua Blue 20cm @ £16.99 inc VAT
Part of the BitFenix Alchemy Premium Modding Series, Alchemy LED Strips are the ideal choice when modding inspiration strikes. These precision manufactured LED Strips come with BitFenix TriBright™ LED Technology for the absolute brightest LED strips available. Alchemy LED Strips come in both chainable Connect and waterproof Aqua, and offer a multitude of lengths and colors, enabling you to bring your modding vision to light.
When only the brightest will do, BitFenix TriBright™ LED Technology gives you the industry’s brightest LED strips. TriBright uses independent ICs to power each LED bulb for maximum brightness.
Alchemy LED Strips are made using a precision SMT manufacturing process, which means the highest quality, enhanced current conduction, and prolonged life.
Have a special idea that needs an extra-long length of LED strips? No problem. With Alchemy Connect LED Strips, you can connect as many strips together as you need with the only limitation being your power supply's current.
BitFenix Alchemy LED Strips are backed with high-grade adhesive from 3M™, which makes sure that your LED strips will remain where you left them, even when your computer is being moved around.
- Colour: Blue
- Length: 20cm
- LEDs: 6
Only £16.99 inc VAT.
ORDER NOW
BitFenix Alchemy Premium Modding LED Strip - Connect Red 12cm @ £9.29 inc VAT
- Colour: Red
- Length: 12cm
- LEDs: 6
Only £9.29 inc VAT.
ORDER NOW
BitFenix Alchemy Premium Modding LED Strip - Connect White 12cm @ £9.29 inc VAT
- Colour: White
- Length: 12cm
- LEDs: 6
Only £9.29 inc VAT.
ORDER NOW
BitFenix Alchemy Premium Modding LED Strip - Aqua Orange 20cm @ £16.99 inc VAT
- Colour: Orange
- Length: 20cm
- LEDs: 6
ORDER NOW
- Colour: Blue
- Length: 20cm
- LEDs: 6
ORDER NOW
- Colour: Red
- Length: 12cm
- LEDs: 6
Only £9.29 inc VAT.
ORDER NOW
- Colour: White
- Length: 12cm
- LEDs: 6
Only £9.29 inc VAT.
ORDER NOW
- Colour: Orange
- Length: 20cm
- LEDs: 6
ORDER NOW
