How much is a decent loop going to cost me?
1 Jan 2013
England Rugby
I've had a quick read through the watercooling guide so I have a vague idea of what I might need to buy but I have no idea of what is good now. I'd want to cool a 7950 and an i5 760 and i can fit 2 240MM radiators on my case so I was just wondering if any could give me a rough estimate on how much a mid range loop would be costing me? And any reconmendations on the parts.
Thanks in advance
Not sure on the parts as each case can fit different combinations but i would set a budget of £300 to £400 for what you need.
Oh right fair enough. I'm really worried as someone who's never fitted any sort of water cooling before I don't want it to go wrong and me brake my whole PC. Is it really as big a challenge as it seems?
If you haven't done a loop before then take some time to watch some videos on youtube.
My first one was nerve wrecking but ive had 4 loops now and they are pretty straight forward and easy enough.
Ahh right ill be sure to do a lot of research before hand because the last thing I want is to mess up and reck everything :(
Thanks for the help!
Yep do plenty of homework on building loops, it'll become a breeze though after you get your first loop done and you tinker with it :)
I did my first loop over Xmas....
- First thing you want to be doing is getting a side view pic of your case and drawing a rough plan of the loop you plan to use.
- Once you've drawn it out, post it on forums and ask some of the w/c lads if they think it's ok.
- before you buy anything, ask on the forums if the rads would fit in the case. You get better cooling from thicker rads so get the tape measure out.
- A good place to start if you've never done it before is one of the OcUK kits. You can add bits in to the kit like extra hose or coolant if you want.
The most nerve-racking part is the initial fill up of the res and the first time you jump the pump. Once the coolant is flowing round without leaking your nerves get a bit easier.
The only downsides of watercooling are
The extra cost
The fact that if you get a part of your loop that isn't doing it's job properly, then you have to drain it. You're more likely to get something wet draining it than fill, so when you design your loop, plan for easy drainage if something goes wrong.
The extra cost
Ahhh I see! Ill try and get something like that up asap.
Fractal cases have never been great for wc, could you give us some depth measurements from proposed rad locations?
Quick question ... what are you trying to achieve by watercooling your system?
A cooler system of course but more importantly the 'adventure' of fitting it and making it all look good but work well at the same time. Just something as like a little mini project on my computer.
