Building my PC for gaming, won't be overclocking.
11 Sep 2012
Hi all
This is the guts of my build, without the ram as I'm getting 16gb from a friend and a MB elsewhere as OCUK dont have the one i want.
Will my temps be okay for gaming etc? I will only overclock when I get water cooling, but the stock intel cooler should be fine?
Is there a cpu cooler on OCUK that's under £30 and will be better than the intel stock cooler?
Oh and disregard the mouse :D
YOUR BASKET
1 x Gigabyte ATi Radeon HD 7950 Windforce 3X 3072MB GDDR5 PCI-Express Graphics Card £239.99
1 x Intel Core i5-3570K 3.40GHz (Ivybridge) Socket LGA1155 Processor (77W) - Retail £179.99
1 x BitFenix Prodigy Mini-ITX Cube Case - Midnight Black £56.99
1 x XFX Pro 550W Core Edition '80 Plus Bronze' Power Supply £49.99
1 x **B Grade** Seagate Barracuda 7200.12 500GB SATA 6Gb/s 16MB Cache - OEM (HD-252-SE) £30.00
1 x TP-Link 300Mbps High-Gain Wireless-N USB Adapter (TL-WN822N) £16.19
1 x Gigabyte M6900 3200DPI Gaming Mouse £14.99
1 x Xigmatek XLF-2004 Blackline LED Fan - 200mm £9.98
1 x Arctic Cooling MX-2 Thermal Compound (1g) £0.59
Total : £612.80 (includes shipping : £11.75).
What mobo are you getting? This is important, because of the layout of some mITX boards, some air coolers can over hang the Gpu slot.
As per my message, i've now gone over budget so water cooling will be my next step but not for a few months. My previous water setup won't fit in this build so I'm going almost all stock but i wanted a aftermarket cooler thats better than the intel but under £30 or around. give or take £5.
The mobo is: http://uk.msi.com/product/mb/Z77MA-G45.html
Which I just found on OCUK :)
That`s a mATX board not mITX, so will not fit in the Prodigy.
You want something like this.
YOUR BASKET
1 x Gigabyte Z77N-WIFI Intel Z77 (Socket 1155) DDR3 Mini ITX Motherboard £98.99
Total : £107.69 (includes shipping : £7.25).
