- 17 Apr 2010
No.
The all in ones aren't as good as something like a silver arrow.
What about H100i/Kraken X60? Twice the price I know!
No.
Oh, no sorry.
1156 was the new one, they kept it with 1155, and are meant to be keeping it with 1150.
H800i's barely better (We're talking like less than 1 Celsius difference) than a silver arrow.
Pretty pleased with my 30nm RAM doing 2400Mhz, although I've backed the timings off to 12-12-12-30 so I'll see if I can get that back to CL11 later.
Edit, nope RAM maybe not stable needs more work!![]()
Not Realy a AMD Cpu but i got my intel i3 540 @4.7ghz.. and could still go higher.. and boots into windows. Not tested yet but im running 4.2ghz atm
nice to see you guys posting your actual use speed of 4.5-4.6 like i said would be months ago
5 ghz is too much for these and gibbo you naughty boybit of a false sales pitch tbh. but i guess it shifted a lot of pd chips
Clearly an Antec 620 isn't a great water cooler.
This. I did get 4.8GHz with my silver arrow but my temps were too high. Core temps read 65 degrees during an hour and a half 1080p encode in Handbrake. Was a bit nervewracking. I'll see if I can dial down the voltage a bit and maintain the speed but I can run 24/7 at4.6-4.7 with temps in the high 50's only under heavy load. I won't get 5Ghz without a custom water rig. Might have to wait until next septembers OU grant and get a bigger case and the gubbins to try it. Still, more than happy with the performance I've got now.You need proper water cooling for higher 24/7 clocks with these, then it's very possible to achieve 5ghz. But it also depends on the chip you get and the board you've got. I got a stinker, on a decent board, and still manage 4.9ghz 24/7.
You'd be lucky to get 4.7ghz on air.
