Hey all,
I've had this problem for a good while now and it's getting to the point where it kind of drives you crazy lol. Whenever my pc is running I can hear a quiet but constant humming type noise (not unlike a warpcore from Star Trek).
Just for info I have a HAF 932 case which I think may be causing the problem.
I've checked all the fans, they're all working fine and when I've disconnected them all one by one the noise remains (plus with them all off). I have a no maintenance closed watercooler for my CPU (Antec) which I've also disconnected, yet the noise remains. I've pulled the Hard Drive's out of the tool-less bays and the noise remains...I've prodded around the motherboard, PSU and no matter what I do the noise remains the same, not even an alteration like you would expect if you prodded the part where the noise was coming from where I imagine the pitch or frequency of the humming would alter.
I've recently purchased silicone washers and put them on all the screws I possibly could that hold components together and installed silicone anti-vibration kits on the fans that I could get to fit (so on all the 120mm's). At the point now where I need help! lol. It's inaudible during gaming sessions, watching movies or listening to music but as soon as there is little to no sound it can be heard clearly...so if I'm on the computer reading or doing some work in MS Word, Excel etc..there it is, in the background like a dull droning noise!
So I'm at a loss for what it could be...
Anyone else experienced such issues in the past?
Thanks all!
Thanks all!
