Road Cycling Essentials
Status
Not open for further replies.
quicker? forget it! :) more grip yes but no way is it going to be quicker :eek:
There are a few scientific articles floating around that explain why lower pressures have less rolling resistance.
I still run my tyres at 100+ psi, but that's on 25mm tyres.
I'm about the same - 110 front and 120 rear. I'm quite anal with tyre pressures, I usually check mine before each and every ride. That's 700x23's btw.
I thought lower pressure will give a comfier ride as it allows the tyre to deform more over bumpy surfaces instead of bouncing off. I think if you are lighter you can get away with lower pressures but I still run 100/105 on my 22mm front and 24mm rear.
That's probably right though at those widths. They're pretty narrow and would need more pressure to deform less. At too high a pressure though you get a lot of bounce.
I've just read this and it makes a bit of sense but it still seems odd that squishier tyres would roll better.
Bike fit....
Im considering one soon, but have one problem with some of them.
I was initially going to go for a basic rutal fitting ie through, bike science or swift cycles in london.
Then someone recommnded online, thebikewhisperer where they dont use eletronics but pure know-how ect.
Sounded really good, but then i saw prices.
234 quid for bikewhisperer compared to apox 150 for retul fitting.:eek:
Holy cow, thats a insane diference.
My question i this, how can they justify that price? and is it really that much "BETTER"???
Need some advice from those who have had both or have had one .
cheers
The Bike Whisperer didn't used to charge that much, closer to £150. I'm guessing that their popularity (getting an appointment is difficult) means they can push their prices up.
I had my Specialized Body Geometry fitting at Sigma Sports. No electronics, £120 and I'm very happy with it.
Anybody else get the strong urge to ghosty their bike into cars that pull into you when exiting or entering a left-hand junction while you are going straight? I bet 12kg of steel would do some damage to their cars! :mad:
And in more important news - Cavendish won again today at the ToQ. He is also 1st on GC. Two stages in the bag and great form points to good things for the Season.
I havnt seen any video of this race yet (stupid eurosport :() but i was following on twitter and apparently they dont have a very good leadout?
I'm not sure if thats a good thing or not, it's great that cav can win without a train but it will be harder when he's up against Greipel, Sagan, etc.
Ok, I've tested it out and in my not very scientific at all experiment I've concluded the following:
Cruising on rough roads is definitely less tiring
Acceleration off the line sucks
Overall speed is marginally quicker
So there. Also my new wheels have arrived! 32h Mavic Open Pro on 105 hubs. Just need some new tyres now so I've got two complete wheelsets to swap between.
Edit: Also I picked up a chain tool with my wheels. Apparently my chain is completely worn. I only got the bike in Sept and the chain's been kept super clean! WTF? It's not been skipping or anything either. I'm guessing chunky guys climbing hills isn't good for chain wear. Now I need to get a new chain (and possibly a cassette) :(
I generally run at 80-90psi but that's 25mm tyres on 23mm rims as opposed to standard 19mm ones.
I ran the Marathon Winter tyres at 35psi in the snow. Overall speed sucked, but that wasn't really the point.
I learnt that lesson the hard way too. The LBS likes to keep that a secret until you've had to replace your chain, cassette AND chain ring!
I think most chains that come with cheaper bikes are rubbish. I've ridden way more miles on the KMC chain I have now than the stock one and my Park Tools chain wear tool still says it's doing fine.
PS. Get a KMC chain!
tell me about it.. so annoying! its like racism lol, if you dont have an engine you SHALL NOT PASS! :mad:
my triban came with a kmc z7 chain, its cheap but gets good reviews!
http://www.chainreactioncycles.com/Models.aspx?ModelID=51830
gave it a good clean and its all good now, has the shimano splittable link too so really easy to take off
Status
