Ozone's new gaming keyboard.
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
Pre-order the new Ozone gaming keyboard!
OcUK have secured an exclusive on this product, so you will not get it anywhere else!
Ozone Blade Backlit Gaming Keyboard @ £52.99 inc VAT
A stylized and aggressive design with back-lighted keys combined with hot gaming features makes Ozone´s Blade in a complete gaming weapon sharp as a knife. The 128 Kb on board memory together with the software included allow you to fully customize the keyboard saving up to 50 different macros in 5 different profiles. And if you are tired of exiting the game accidentally by pressing the windows key, Blade´s game mode option will allow you to disable the windows key when you are in the middle of the action.
Get a stunning look in the dark with the Blade´s back-lighted keys. Choose from the two available colors, red or blue, and adjust the light intensity to your needs on-the-fly.
Blade´s profile management allows you to save up to 5 different profiles and change them on-the-fly. Switch to your game or character-specific profile immediately.
Easily customize your commands and abilities saving up to 50 macro keys using 5 different profiles. Hot keys, shortcuts or a whole key sequence can be easily saved.
Take your preferred gaming profiles everywhere and use them on any system with Blade´s on board memory. Store up to five unique user profiles and 50 different macro keys.
- Multimedia gaming keyboard
- Dual back light (red or blue)
- 10 Macro keys
- 5 Profiles
- Multimedia keys
- 128Kb On board memory
- 18K gold plated USB Connector
- Anti-ghosting capability
- 8x Faster –1000 Hz Polling Rate. Response time 1 milisecond
- Dimensions: 510 x 199.8 x 30 mm (Length*Width*Height)
- Approximate Weight: 1.14 kg
- Cable length: 160 cm
Only £52.99 inc VAT.
ORDER NOW
Why does almost every gaming keyboard have to look like a cylon from battlestar galactica?
Do manufacturers think all pc gamers are 14 year olds?
It was so funny the last LANparty I attended, everybody was there with their fancy energy drinks and their Razr/Logitec/Saitek/etc gear and when I pull out a 2ltr bottle of Pepsi Max and started setting up my 17 yeah old Cherry G80 and my 10+ year old Intellimouse Explorer (Optical Edition) jaws hit the floor ^^
There products are selling then...
I think its a nice keyboard but huge price seeming that a mechanical keyboard isn't that much more expensive
Yes, black and beige are the only 2 colours in existence.
Silver - looks cheap unless it really isn't i.e Alu, machined stainless
Grey - bland as black but not bad if accented properly
White - gets grubby and looks like an Apple knock off
Brown - brown!?
Blue - who wants a blue keyboard?
Yellow - Will look lovely after a weeks use
Orange - Ok, I could live with that, perhaps
Green - yuk, unless Lambo lime
Red - unless you launch nuclear missiles for a living, no
Pink - ghay
Purple - ghay
Clear - Apple did that, it sucks when it gets scratchy/full of dust/dirt
Even if you get a colour you're happy with, it won't match your mouse or monitor. All my stuff has to match :p
There's a reason most keyboards are black, it goes with everything and few would object aesthetically IMO
