Its fairly common for them to jump around between 1-2 degrees. Still seams a bit high since I idle with the stock cooler (same case) at 32 degrees! And my toothpaste version at just under 40You did install the cooler correctly right and use the thermal paste supplied?
Yeh the standoff's got me confused tooBtw how have you got your 2 fans arranged in your case? 1 intake and1 outake I take it (get the pun)
Well I've got every fan position in my Ghost covered nowCant wait to put a tower heatsink plus dual fan GPU in there too
Download realtemp and then compare results? Your idle shouldnt be higher than mine with an aftermarket heatsink....
Edit wait. Whats your load temps again! Idle temps might be high because of room tempature or something...
I put a couple fans out of my old Antec 300 in. An additional one at the front, and an exhaust fan at the top.
Idle does range from 29-33C now. Load (Prime95/OCCT CPU) is high 60's. Hit 70/71 occasionally. Don't think that is that great, right?
Does sound a bit high, how much paste did you put on?
