I very much doubt you would be able to warp a disc, let alone on a road car. Cracking? Maybe with super cheap discs, or on a track if it gets very hot.. Wear rates? Possibly.. but it's unlikely there will be much difference between the 2 discs mentioned in this thread.Bad wear rates, warping, cracking the list goes on.
The point I'm making is you dont go to you local metal supplier and buy some, 'brake disc metal'.
You should consider which discs you buy just as much as you do pads.
<3 the pattern on their grooved discs.Personally I'd have bought Tarox but that's another story.
Who care how good or not BluePrint ADL are... it's not what you ordered and that's what matters.
I put a lot of effort into choosing pads for my track car too, but have always used cheap disks. I have never had a disk warp, even when they`ve been glowing red on track. A PROPER cooldown before coming into the pits makes a big difference.I put a lot more effort into choosing my pads than I did my discs, but to be honest, my car is predominantly a road car, I expect whatever I had chosen (of similar price / intended use) would have been absolutely fine.
