What GPU
21 Oct 2002
Earth
hi folks
Just about to buy a GPU not sure whether 7850 or 7950, CPU is an i5 @4.4Ghz, what would you get, mainly driving games and fancy far cry3 and GTA5 when it's out.
Simon
Heard good things about the 7950, a friend of mine has one and keeps up on most games we play together.
I personally recommend the Windforce 670 if you're open to nvidia, very quiet and very fast. But if you're after ATI then the 7950 seems to be a good buy at the moment.
Loving my 7950 m8, i wouldnt go for the XFX one though if ya sticking to the stock cooler, theyre far too noisey, but theres much quieter ones out there.
well all installed, was a pain in the butt! first off didn't recognize card on pci-e3 slottried a gtx260 i had that didn't work so tried the 260 in pci-e2 slot and second boot it was found, so retried 7950 in pci-e3 slot second boot up bang found it :D installed CCC from amd and just ran heaven and fire strike :)
http://www.3dmark.com/3dm/148414?
