*** League of Legends ***
Smart Casting do you do it and what is it ?
I heard it thrown around by some people !
Smart-casting circumvents the mouse press part of casting an ability. For example, normally you would press Q and then have a range circle appear around your character. You would then left click on an enemy to cast said ability. With smart-casting you simply press Q and the ability immediately gets used on the target underneath your mouse cursor, without you having to click or the range circle appearing.
Since you have one less key input it's required to use if you play in a med-high latency environment as it basically halves your ping as far as casting is concerned. Past that necessary use it's down to personal preference, I'd recommend sticking to the normal way while you learn all the cast ranges at least though (since you will never see the range circle again). You can always use Shift+QWER if you feel like smart-casting at any point anyway. Quite a lot of people, myself included, have switched these controls around and smart-casting is the default behavior of our QWERDF keys (having the Shift modifier used for the old way instead).
What about spectating, how exactly do you do it?
Right click on anyone in game on your friends list and you will be given an option to spectate them. Alternatively there is a ticker that scrolls through High Elo solo queue games on the front page of the client (if that sort of thing floats your boat).
Hope that helps :)
Hope that helps
Certainly does, thanks!
Can someone recommend some good cheapish hero's I could try out, I'm looking for something different to Master Yi since that's all I've played really.
I was saving for Pantheon and should maybe have enough late tonight, though not sure if i should maybe buy a few cheaper ones.
Skip Pantheon mate, he's simple to play and fun but when it comes down to it and you start caring more about doing well in game, he's useless after lv14
Quick question. In the early levels should you still be buying runes albeit you can only get the very weak ones? Or do you need to save the ip for the larger ones in later levels?
no dont bother, just wait to l3 runes kick in.
The amount of players I still see in ranked with hardly any runes is astounding.
Wait to level 20 which is the level that you unlock the highest rune tiers. It's also good to have around 10k IP saved so you can buy all the runes you need for one page.
Will do. Have bought some previously but will wait for now.
Decided to buy some cheap hero's and started with Garen and just had one of my best games. 10k 3d 3a. We did get beat mind you but still went quite well. Though now 4 defeats in a row.
Kills are important but farm is also important, so you want to be bearing that in mind. At lower levels focus isn't really given to that so the more farm you get the stronger you will be comparatively. Remember get the last hit to keep the lane where you want it and try not to push the lane unless you are doing it for a reason, ie to go wandering.
How are you getting on with the champs you are trying?
I'm on tonight at 7:00pm if anyone wants a few games, add Claymech - Willing to play any role if needed just wanted to clear that up :d
there the worst, 2 times yesterday i was in my BO3 games and lost because of complete idiots.
like a taric that went this retarded build(ancients and hourglass), no tanky at all, and he was duo with this draven that basically thought it was great bc the support got some kills with it (yes really) >.<
we lost bc they had 3 tanks and only me as a tank (olaf) yet they blamed me bc i had no damage, but could tank 3 of the enemy, and i tried to get the taric to sell up and go tank but he was just troll chatting with his mate as backup. ****ing idiots
we lost bc they had 3 tanks and only me as a tank (olaf) yet they blamed me bc i had no damage, but could tank 3 of the enemy. ****ing idiots
Did you roam to bott lane pre 15 minutes?
