Flash memory is limited by a fundamental access time: for 25nm Intel flash it takes 50 microseconds to read 8kB; this translates to 156MB/s, per NAND chip (with typically 8 or 16 NAND chips per SSD that can be accessed in parallel). Yet typical SSD sequential read speeds are 200-400MB/s.
So, in theory, there is still scope for improving SSD controllers (as well as the SATA interface/host adapter) even further. But, for present drives, it's unlikely that there's anything useful that could be tuned by the user that the manufacturers have not already considered. I suspect that the cost and complexity of the SSD controller sets these boundaries on performance.
so unless you can make your own controller or board or write your own bios instructions, can't see how you could hope to achieve any real gains, apart from raid0 etc or setup a ram drive for the sdd to use, as normal ram can be 20x faster than sdd so that could be your answer?
