Nasty unknown virus!
20 Aug 2007
Solihull
This is a video of a virus that affected a user at work, I have no idea what it's called, can anyone shed any light on this? Perhaps a removal procedure as well, I'll probably end up wiping the HDD and going fresh but it's good to know.
You need to run Regedit from Run (windows key + R) then find it in the software part and end it then end the exe from task manager.
Right, this thing sucks.
First off, run combofix: http://www.bleepingcomputer.com/download/combofix/
You might need to run it from safe mode but it will kill the system recovery virus.
Then this: http://www.bleepingcomputer.com/download/unhide/.
This will make your files reappear.
You aren't finished yet!
It's probably part of a rootkit, so run this: http://support.kaspersky.com/downloads/utils/tdsskiller.exe
(I couldn't get this to run, so I had to use a kernel editor to delete a load of callback functions first - ask me if you can't get it to run!).
If it found and removed a rootkit you now need to run a virus scan like Malwarebytes - it will find a ton of viruses it didn't find before.
Good luck!
Edit: Looking at your video again it looks identical to the one I had, so the steps above should work perfectly. Don't miss out the rootkit removal step, you probably have a few other amusing viruses like google redirects that won't be picked up by your antivirus until tdsskiller removes the rootkit!
Surely the problem is that system repair is installed?
System repair is Malware that fakes a totally trashed system, check google for how to remove it.
AD
AD
Was actually just thinking the same thing. the .exe is usually found under the users profile.
Should have made a complete image before doing so, and run the image on a VM and seeing what methods of removal worked.
The thought did cross my mind, but as I'm delegated to a ridiculous amount of tasks in this job role, I didn't have chance :( I do everything from internal IT, to Office 365 consultancy, account management, tech support and handset repairs and loan tracking! :c
