- 20 Jul 2009
- The bleak North East arm pit of Britain
Hello
Deals for the weekend are as follows!
Kingston HyperX Beast 8GB (2x4GB) PC3-12800C9 1600MHz Dual Channel Kit (KHX16C9T3K2/8X) @ £37.99 inc VAT
Unleash the Beast on your system. The vicious HyperX® Beast features a dynamic new heatspreader to maximize thermal dissipation for increased reliability. Plus it looks really cool and enhances any system. It’s Intel XMP ready so higher-performing frequencies, timings and voltages are just a few clicks away. The Beast gets along well with third-generation Intel Core i5 and i7 processors and the latest AMD performance and gaming processors. Put the Beast in your corner and crush your opponents — or just conquer your challenging workload.
Features:-
- Capacity 8GB (2x4GB)
- Speed: 1600MHz
- CAS Latency: 9-9-9-24
- 1.5V-1.65V operating voltages enable stable overclocking
- Compatible with Intel XMP auto-overclocking function
- Designed to work with P55, H67, P67, Z68, H61 (AG), X79 and Z77 Intel chipsets; as well as A75, A87, - A88, A89, A78 and E35 (Fusion) AMD chipsets
- Carefully selected premium chips for maximum performance and overclockability
- Dynamic black design and sharp edge accents
- 100-percent factory tested
- Lifetime Warranty
Was £44.99 Inc. VAT
Only £37.99 inc VAT.
ORDER NOW
Gigabyte ATi Radeon HD 7950 Windforce 3X 3072MB GDDR5 PCI-Express Graphics Card @ £239.99 inc VAT
GIGABYTE introduces the latest exclusive "Triangle Cool" Technology to reach a better cooling performance. The latest patent pending technology combines fin with clip module in a special triangle shape. With the original anti-turbulence structure plus the new triangle cooling design, it enhances the efficiency of heat dissipation dramatically by minimizing the flow of turbulence between fans. Therefore, the "Triangle Cool" Technology provides a more efficient air flow for the cooling system.
Ultra Durable VGA board provides dramatic cooling effect on lowering both GPU and memory temperature by doubling the copper inner layer of PCB. GIGABYTE Ultra Durable VGA can lower GPU temperature by 5% to 10%.
Ultra Durable VGA board reduces voltage ripples in normal and transient state, thus effectively lowers noises and ensures higher overclocking capability. GIGABYTE Ultra Durable VGA graphic accelerators improve overclocking capability by 10% to 30%.
Ultra Durable VGA board allows more bandwidth for electron passage and reduces circuit impedance. The less circuit impedance, the more stable flow of current and can effectively improve power efficiency. GIGABYTE Ultra Durable VGA can lower power switching loss by 10% to 30%.
Features:-
- Core Clock: 900MHz
- Memory: 3072MB GDDR5
- Memory Clock: 5000MHz (Effective)
- Memory Interface: 384-Bit
- Processing Cores: 1792
- Bus Type: PCI-Express 3.0
- Display Connectors: 1x Dual Link DVI, 1x HDMI & 2x Mini-DisplayPort
- HDCP Capable
- DirectX 11 Support
- OpenGL 3.2 Support
- ATI CrossFire Ready
- ATI Eyefinity Technology
- ATI Avivo HD
- ATI Stream Technology
- ATI HD3D Technology
- Warranty: 3 Years
Was 249.95 Inc. VAT
Only £239.99 inc VAT.
ORDER NOW
Features:-
- Speed: 1600MHz
- Lifetime Warranty
Was £44.99 Inc. VAT
ORDER NOW
Features:-
- HDCP Capable
- ATI Avivo HD
- Warranty: 3 Years
Was 249.95 Inc. VAT
ORDER NOW
