Some suggestions please.
20 Nov 2010
Hello,
Afer some feedback on another thread :
http://forums.overclockers.co.uk/showthread.php?p=23565767#post23565767
YOUR BASKET
1 x Asus PB278Q 27" Professional LED Multimedia Monitor - Black £499.99
1 x Intel Core i7-3770K 3.50GHz (Ivybridge) Socket LGA1155 Processor (77W) - Retail £239.99
2 x EVGA GeForce GTX 670 Superclock w/Backplate 4096MB GDDR5 PCI-Express Graphics Card £359.99 (£719.98)
1 x Samsung 256GB SSD 840 PRO SATA 6Gb/s Basic - (MZ-7PD256BW) £209.99
1 x Seasonic X-Series 1050w '80 Plus Gold' Modular Power Supply £189.98
1 x Gigabyte Z77X-UD5H Intel Z77 (Socket 1155) DDR3 Motherboard £158.99
1 x Corsair Graphite 600T Midi Tower Case - Silver £149.99
1 x Asus Xonar Essence STX Sound Card £119.99
1 x Corsair Hydro H100i High Performance Liquid CPU Cooler (Socket 1155 / 1156 / 1366 / 2011 / AM2 / AM3 / FM1 / FM2) £96
1 x Patriot Viper "Black Mamba" Generation 3 16GB (2x8GB) DDR3 PC3-17000C11 2133MHz Dual Channel Kit (PV316G213C1K) £89.99
1 x Liteon IHOS104-06 4x BD-ROM (Black) - OEM £29.99
1 x Corsair SP120 Performance Series High Pressure - Dual Pack £25.99
Total : £2,548.56 (includes shipping : £14.75).
I decided to buy the above items, the motherboard I changed but the one I picked was the same dimensions. After starting to build this setup I've hit a few problems so far.
1.The H100i will not fit in a push / pull setup with this case and motherboard combination.
2.The SP120 fans cannot be controlled by the H100i fan controller (I recently found this out on the net I have not tested it myself yet).
Based on the above problems I have a couple of options.
1. Get a different case and go push / pull in that case also getting a fan controller for the SP120's.
2. Stay with my current setup just using two fans on the H110i, and not using the SP120's
3. Rethink case and cooling.
Just wanted to get some feedback and see what other people thought.
Thanks,
Rick
Don't bother with push and pull, the temps will be decent enough with the H100i. Use motherboard headers for SP120's.
yep putting two fans on the outside of the case, the fans on the inside just won't fit.
The problem is the memory getting in the way.
As above, if thats the case no need to.. The Sp120 may be quieter than the standard fans.
