Just give it up and move to water matt![]()
Not yet, not on this build. My next build, whenever that may be, im considering it. Never done watercooling before so.
Yep, the Lian Li A70 which is the previous model to the A70F which i have offered this. Those fan points were removed on the F model. Bit of a backwards step tbh. The hdd cages on the 70F are a bit restrictive, however swapping the stock fans for 2x silverstone air penetrators made a vast difference.
Not yet, not on this build. My next build, whenever that may be, im considering it. Never done watercooling before so.![]()
Well im waiting to hear back from tommy regarding something we've been looking at and he's trying it first so ill hold off for now. The spot would look better in my case.
Tommy has Italian blood in his veins, these things take time to achieve because we take things easy, as(probably) to get a bigger response.
I'm still at work, so won't be today, if I'm lucky, late tomorrow night or Monday night.
The AC has a sort of lip on the shroud, you can attach a 120mm fan slap bang on it(flat onto the 7970 writing) nesting right up against the pci-e power cables, almost bang on the vrms, if you can get a hold of some wire and feed it through the fan mounts and attach it to either side of your case, simple, effective and free if you have a spare fan kicking about.
I think you guys have convinced me. I haven't answered the question myself, people have just me understand the situation.
Nvidia cards at the moment are way overpriced and give next to 0 benefits. If I buy an AMD card, I get pretty much everything I want, my 3GB vRAM (Perfect number, 4GB is overkill, 2GB is dangerous), the best performance I can possibly get, a cheap price, and solid drivers.
Got them in both my cases, however i tried the 120's on my k2 cooler. Not great tbh. The 140's dont fit the k2 due to the fan clips only working on square framed 120mm fans. Currently running theese on the cooler.Used to love those SST-AP121's when I was on air, probably the best intake fan on the market, a shame they are relatively weak in other areas, I will be sad to see my last AP121 get sold when I rebuild
http://www.overclockers.co.uk/showproduct.php?prodid=FG-073-AK&groupid=701&catid=2331&subcat=4
Even better than scythe gt's that i tried before.
thats life
Wow, topic seriously jacked xD
I need to find some decent prices for 7970s or 7950s now then.
I'm not sure which I should go for...
Reckon I should go for a 7950 rather than a 7970?
Get a 7970ghz edition and laugh at all the peasants below you. (apart from those with insanely good clocking 7950's)
